I have several domains that have gone down intermitantly since yesterday. I submitted a ticket a short time ago, yet the ticket system did not deliver an email even. I have not touched the control panel in at least 2 weeks.
As the ticket system is not even acknowledging submission by email I felt I was not going to get a response email if I need to change something.
I did check before submitting the ticket that the IPs for NS1 and NS2 are resolving to the previously communicated IPs. When I put the IP addresses into my registratar resolves them and changes the name to NS1.G********.COM and NS2.G********.COM.
if it resolves the IPs, you are putting in the wrong section.
that is ‘nameservers’ section, there will be a special area for setting your custom nameservers, on our domain control panel it is called Child nameservers
I have personal domains at godaddy and it is ‘Host Summary’ (on domain control panel, scroll down past summary and will be on left bottom)
Thanks Stephen, I dug in deeper with NSLookup and was getting the old IPs out of my registrars system about 3/4 of the time, yet their control panel showed the right IPs. Calling them revealed that they had both sets cached and had to force a flush to clear the old IPs.
As A side note I dug back through my email and there are no emails from Jodo on the 18th at all, It might help to send it back out once again to ensure coverage.
You may want to verify contact info in contact info section and billing section of the CP, we did get a few bounces, but not many considering all that went out
it was also the 3rd email mentioning it, and the 5th or 6th about migrations in general.
i PMed you those IPs just in case you had need of them, glad you are working to get it sorted.
Do you know how long propagation normally takes to occur? And I’m referring to root DNS servers not TTL on normal DNS records as that I believe is entirely different.
