domain not working
Im trying to set up this domain: nataliatesta.com.ar, but, even when its already pointed and delegated, I can not access it (I get “server not found”).
Maybe we have too much domains for our current four DNS?
Thanks in advance,
Ignacio.
There should be no issue with too many domains :slight_smile:
You have nameservers properly setup I take it, any others with com.ar domains? If you do that should not be an issue, sometimes the country nameservers can be a bit picky about naming of hte nameservers, but as long as you follow standards like ns. or dns. (with number appended) they typically work.
Thank you Stephen, everything seems to be working fine, now.
See you next,
Ignacio.
