Domain physical path
Hi there
I am in the process of setting up a forum, and need to edit the web.config file to indicate the two properties below:-
Obviously I have answered the first one, but what would my physical path be?
Thanks in advance
Brian Candy
D:\hshome\ftplogin\domain.com\instantforum34\skins\
Thanks for the prompt reply… that sorted that one out :))
anyways, it’s recommended to use a command to get the path in case your site is moved. in Classic ASP this is done with Server.MapPath(). I’m not sure how it’s done with .Net though
[QUOTE=bcandy]
Hi there
Use any of these (C#):
Request.PhysicalApplicationPath+@“\forum\skins”
Or
Server.MapPath ( “/forum/skins” )
