domain transfer problem
I am trying to transfer a domain from jodohost (domainsgofast) to godaddy.com, but I am getting this error:
However, the current status of the above domain name(s) is:
clientDeleteProhibited, clientRenewProhibited, clientTransferProhibited
I have unlocked my domain, why am I still getting this error?
is it within 30 days of expire?
yes.
This is likely the problem here, it isn’t a limit we set, it is a limit set by all registrars, including our backend. you will have to renew here, wait 60(30 now, 30 after expire would have happened,technically could be 30 days but up to 60) days then transfer and get the 1 year extension at godaddy when you do that.
if I do as you say, are you sure I will get a 1 yr extension at godaddy.com?
Yes, it will be the case. I have done it before from namecheap to godaddy.
