Domains for DNN Child Sites
If you have a child site from a DNN portal, what are the steps to set up where the child site can have it’s own domain name instead of yourname.com/childname?
You set up the domian to be another alias for the main portal. And then setup the domain in DNN. I think. I know I did this but don’t remember the exact steps. I do know you don’t register it as a new domain under the jodohost control panel. DNN needs to handle the url rewrite.
Yes it should be an alias to the master portal domain I beleive. Then jsut create your new portal with the child domain and all should be fine.
