DotNetNuke 3.0.12
Now that DotNetNuke 3 is realeased and is no longer in beta are we good to install it?
JMKotman
JMKotman,
I will give permission for you to install it and we will evaluate systems for 3 days after you have it running, then I will make a a global acceptance or not.
Refer the techs to this forum post when you create your ticket. We will still need the standard info so we can grant the proper permissions for you.
Did the test pass ?
If so can we upgrade to 3.0.12 ???
Andy
I never got a chance to install it yet. I plan to install it this weekend.
JMKotman
We are currently assisting customers with DNN 3 installs since it is now out of BETA testing.
So yes, you can upgrade to the latest stable version
Just as a note to everyone, I would RECOMMEND a fresh DNN3 install, we are seeing some upgrade related issues.
It seems there are quite a few people having problems with the upgrade process, but fresh installs are fine.
