I’m thinking of developing a site (for an aviation artist) using DNN 4.x. Does anyone have any opinions for or against DNN? I’m not that familiar with it.
Thanks.
Thanks.
DNN is very good software although a little slow the first time you load a page.
In other hand, it is difficult to develop new modules and features. You must be .net expert and DNN expert. If standart modules are enough for you this is a good tool, but if you need to create new modules you would study first if you will can do that.
Hmm..thanks for the heads up. Maybe I’ll leave it for a while yet.
Thanks.
We recommend DNN for all our web clients – we have maybe 15ish clients running on DNN 3.x or 4.x right now. Extremely customizable. We find that many people want some of the add-ons that do cost a bit – some common ones are form creators, slideshows, etc – these typically run < $50.
Check out www.snowcovered.com to see some easy add-ons.
JODO staff does pretty good helpin with the set-up, as well (permissions).
tim
Hmmmm! Maybe I won’t leave it then!
