I’ve been struggling getting drupal to install on web6 all day.
I’ve given up on the older version and loaded the current 6.1.6 version. However when I hit the /install.php and click Install in English a blank page is returned.
I have found this information about this. It is the exact problem I’m having. How can I edit the php.ini file OR is there something Jodo needs to do every time I install Drupal?
online post addressing this issue:
The URL of the blank page read “install.php?profile=default&locale=en”. I tried searching for a solution but couldn’t find one specific to my problem. In the end, I worked out that the issue was with the timeout settings in php configuration file “php.ini”. To solve this simply increase the max execution time to 60 seconds. This is done my editing the following line in your “php.ini” file.
max_execution_time = 60 ; Maximum execution time of each script, in seconds
