I have a website that we recently converted from a CMS system that was written by their previous web company to Drupal. Since we transitioned their site to Drupal, their web traffic has gone crazy. The reports show that they have had over 7GB of http traffic since 9/1/2012. This does not match the traffic that the site should be getting. It is a small restaurant chain and wasn’t getting anythings near that before switching to Drupal.
I have noticed that some of our other drupal sites have seen a big increase in traffic also. Is this something that is normal. Or do you think that the site has been hacked and there are scriptse running that are causing this.
I am not very familiar with Drupal and don’t even know where to start looking for what could be causing this.
After we converted a site to Joomla we were getting a HUGE amount of traffic (3-4 GB) from the search engines (way more than normal visitors) - apparently re-indexing. It went on for a couple of months before it finally fell back in line with normal traffic. I finally discovered this in the stats logs.
I’m not sure if there is a better/easier way to do this, but here’s what I did:
Under AWStats - Robots/Spiders
I just tried to access awstats and webalizer and got a 403 error. Stephen, can you make sure that the site is set correctly for monitoring stats? www.thetinfish.net
This one shows 151MB, which does seem to be pretty excessive - is this all from Tin Fish?
My experience was with a site that had several hundred pages and several thousand images in dozens of galleries and lots of image descriptions. I wasn’t too surprised by the search engines spending a lot of time…
However - and I’m not an expert - I wouldn’t think they could spend that much time downloading Tin Fish unless there was a lot of content I didn’t see!
To feed the paranoid side of this - I had quite a few Joomla sites get hacked with all kinds of stuff uploaded, and hundreds of MBs of data stored in the database tables.
You might check PHPMyAdmin and see if any of your tables have suddenly grown - anything more than 1 MB would be suspect. In my Joomla hack I found several tables with 100’s of MB of data (most tables were only 100’s of KB in size, so they were easy to spot).
