For the past couple of years I’ve always had SpamAssassin disabled on my primary domain at JodoHost. Instead all my mail passes through my local mailserver which runs my own SpamAssassin.
Would I be correct to assume that any domain with SpamAssassin disabled would still have it’s mail go through DSPAM, possibly getting tagged, but not getting deleted, since the H-Sphere anti-spam part is handling that?
If that’s the case, I can add a similar rule to my home SA configuration that takes the DSPAM tag into consideration. If not, how do I prevent mail from getting deleted at JodoHost?
Not that I generally mind with the volumes I’m getting, but I just want to have the option of quickly disabling it in case of a suspected problem.
are you using dspam?
Because it is not yet done clusterwide(will be posted here and mailed as we proceed).
Those who manually moved to dspam are the only users at the moment.
