Dundas Mailer
Hi
I have been trying to use Dundas Mailer component to validate email address on a form. But each time the code is run the login box always pops up requesting username and password.
When I run on my machine it works find.
Here is my code:
objMailer = Server.CreateObject(“Dundas.Mailer”)
    errNum = objMailer.ValidateAddress(txtEmail.Value)
    If errNum = 0 Then
        lblValidEmail.Text = "Valid"
    Else
        lblValidEmail.Text = "InValid"
    End If
    objMailer = Nothing
Cna anybody help me?
hi,
registered especially to answer your question… I was looking for the answer myself, could not find it anywhere, so after a bit of playing and reading the error messages I discovered the right syntax.
don’t mind the rest, added for my own use:
dim objMailer
dim errNum
Set objMailer = Server.CreateObject(“Dundas.Mailer”) 'Mailer object
errNum = objMailer.ValidateAddress(“[email protected]”)
If errNum = 0 Then
tempstr = “Valid”
Else
tempstr = “InValid”
End If
response.write tempstr&“
response.write “error code: “&errNum&” look up the error code below
One (1): The specified address was empty.
Two (2): The specified address was too large.
Three (3): The SMTP send operation failed.
Four (4): The specified user was not found.
Five (5): The MX record was not found.
Six (6): The address validation operation failed.
