Dynamic ASP Navigation
Greetings from a sunny Corfu, Greece.
I am trying to create a dynamic navigation, which will be included in each page.
Basically, I am trying to use this string:
pageUrl = Request.serverVariables(“URL”)
which for example may have a value of: “/guides/corfu/beaches”
and manipulate it to write.out:
Guides Corfu Beaches
So that the user has some idea where they are within the site and can at a glance navigate back.
I am not very goog at working with strings, and I imagine someone has already coded something similar to what I am looking for, or I am open to suggestions.
Thanks. Enjoy your day.
Nathan
[QUOTE=Nathan]
Check out the VBScript function Split.
Thanks Logo, that’s a great function I had not ever noticed before.
But, I am having problems using the array that the function creates. The expression below nav_array(i)=null does not work, how else do i tell - before I go out of range?
nav_array = Split(pageUrl, “/”)
i=0
Do Until nav_array(i) = null
response.write nav_array(i) & “
i=i+1
loop
Nathan
Got it:
ii=0
path=“”
for ii = 0 to ubound(nav_array,1)
path=path & nav_array(ii)
if ii<ubound(nav_array,1) then path=path & “/”
<% =nav_array(ii) %>
Next
Thanks for your help Logan, this has really improved and automated my site navigation.
Cheers
Nathan
[QUOTE=Nathan]
Cheers
Nathan
Check out http://devguru.com. It’s a great reference source for web programming.
