I have one account that when they go to www.domain.com/cp/scripts/index.html and click on asp scipts they get a message that says that is not installed. I do I flip to get that installed. The perl scripts are working but the php and asp are not.
You have to turn on the scripts from Web Settings
I am trying…how do i do that…there is no “script enable” button.
your ticket will be answered shortly …
Okay this is only under unix/linix plans… Login to the control panel for the account or domain. Click on web options under the main menu. From there it will go right to the options or to a menu you asking you to select which domain to edit. Click the domain you want to edit or if it takes you there simply click edit “Preinstalled Scripts” from there you can turn each “Preinstalled Script” on or off.
Markey
