A bunch of my clients’ sites that use Flash menus for navigation or use Flash for rollovers (navigation, etc.). Thanks to Eolas and the resulting changes in IE, I need to update those sites to either hack around the changes or to implement DHTML or other solutions.
It’s not my clients’ fault that these changes are required and based on that thinking, I shouldn’t charge them. Should I just eat the cost and update their sites?
As for who pays for it, I think the best solution is to give them a discounted rate to implement the workaround. It’s not our fault either, after all, and sites do need updated for lots of reasons over the years. Customers can’t really expect their site to work forever, no matter what changes happen at the browser level. It’s just part and parcel of having a website. Updates need to be paid for.
Take the example of unleaded fuel. When lead was removed from petrol/gas (in most countries), older engines needed to be modified. Although car manufacturers had to start producing engines that didn’t run on leaded fuel, they didn’t pay for the required changes to older ones, and neither did the oil companies or the service stations. The end user did. Tough poop.
Personally, I think it’s the fault of Eolas and the University of California for being bloody-minded enough to force the change to IE after getting over $500m for doing next to nothing, and Microsoft for not checking the patents properly in the first place. Maybe we should start a campaign to send the parties involved a bill for the time and inconvenience they caused. They seem to have more money than me…
Incidentally, there may need to be changes to other browsers too, if Eolas is going to be greedy enough to try to sue them as well.
You’re correct that as of right now, only those who have voluntarily installed the pre-release patch (or are running IE7beta) will experience the difficulties. But, as of the 11th, everyone will get the update as part of the next system update.
I’ve applied a workaround hack on my various clients’ sites. That went pretty quick for all but a couple of site. So, I think I’m gonna just give them that. But, some of them are considering making changes to move away from Flash as a result of this change. I’ll charge my clients for that, perhaps at a reduced rate.
[QUOTE=skypanther]
I didn’t realise that. You know, it sucks, but that’s life… if the rest of us go around covering up for the big guys, we’re the ones that end up looking like arseholes, not them.
Maybe I’m in a Bolshie mood tonight, but I’ve decided against that discounted rate. If my customers can find someone else to fix Microsoft’s screwups and Eolas’ greed for cheap, good luck to them. I don’t charge enough to give it away.
