Hello, when trying to execute this application I am with this error
Server Error in ‘/’ Application.
Parser Error
Description: An error occurred during the parsing of a resource required to service this request. Please review the following specific parse error details and modify your source file appropriately.
Parser Error Message: Could not load type ‘CommunityServer.Global’.
Source Error:
Line 1: <%@ Application Codebehind=“Global.asax.cs” Inherits=“CommunityServer.Global” %>
Source File: D:\hshome\tdpaz\territoriodepaz.org\global.asax Line: 1
as I can correct it
Hello,
Ensure all the /bin files uploaded properly as well as that global.asax.cs
I am trying to run a called application Community Server ( www.communityserver.org ) and requires ASP.NET 2.0.
I do not know like qualifying the plan so that this version of ASP.NET runs
Thank you.
You can put up a .aspx file like this and access it with your browser to check the exact version being used.
<%@ Page Language="C#" %>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<script runat="server">
protected void Page_Load(object sender, EventArgs e)
lblVersion.Text = System.Environment.Version.ToString();
</script>
<html xmlns="http://www.w3.org/1999/xhtml" >
<head runat="server">
<title>ASP.NET Version Checker</title>
</head>
<body>
<form id="form1" runat="server">
<div>
<p>.NET CLR Version:
<strong><asp:Label ID="lblVersion" runat="server" /></strong></p>
</div>
</form>
</body>
</html>
If it was running into a problem with the ASP.NET version, I’d expect a different error message..
I am a Reseller Hosting and a client requires version 2.0 of asp.net and I do not know like activating it from of control panel.
When running the lines of code that they sent to me I verify that it is running with version 1.1 and need the 2.0 asp.net .
As active him it is version in the server?
So that it can execute the application that it requires “Community Server” ( www.communityserver.org ) .
Thank you.
Manish
August 22, 2007, 1:44pm
6
You have to send us a ticket for ASP.NET 2.0. Then we will do this.
ASP.NET 2.0 needs to enable manually on server.
O.k., how I ask send a ticket for the activation of ASP.NET 2.0 for my client?
Windows or Linux Hosting Customers, with
Date of Signup: Prior to June 23rd, 2007, and
Control Panel: https://cp.jodoshared.com
Please Use: http://helpdesk.jodohost.com/support/index.php for support
Reseller Hosting Customers, with
Control Panel: https://cp.m ****here.biz
http://resellerdesk.jodohost.com/support/index.php for support
Windows, Linux or Reseller Hosting Customers, with
Date of Signup: After June 23rd, 2007, and
Control Panel: https://cp.gohsphere.com
http://cluster2desk.jodohost.com/support/index.php for support
Windows VPS Hosting Customers, please login directly to your
Control Panel - https://cp.jodovps.com for Support (Click Support Center)
