Hi!
ERROR: The IP of one or more of your mail server(s) have no reverse DNS (PTR) entries (if you see “Timeout” below, it may mean that your DNS servers did not respond fast enough). RFC1912 2.1 says you should have a reverse DNS for all your mail servers. It is strongly urged that you have them, as many mailservers will not accept mail from mailservers with no reverse DNS entry. You can double-check using the ‘Reverse DNS Lookup’ tool at the DNSstuff site. The problem MX records are:
11.248.36.66.in-addr.arpa [No reverse DNS entry (rcode: 3 ancount: 0)]
Is anyone else experiencing this failure using the dnsreport.com?
This is occuring for all our domains.
I noticed jodohost.com does not have this issue.
I sent a trouble ticket in on this 03/19/04 and just got we are looking into this.
According to several forums I have read this is not supposed to be hard to correct.
Furthermore, I read that a growing number of email servers will reject email if the Reverse DNS does not work?
Finally, I do not think any client would be too thrilled to run this report and see any failure regarding their domain.
