How do I link plans together so users can move from one to the next?
If I have ASP turned off for now and at sometime I need it and turn it on for the plan with the users who signed up while it was off be able to access it?
How does summary disk usage for a client work? Say I want to give them 100mb storage. Do I say 100mb for email, disk space, mssql etc..?
We only install reliable 3rd party custom tags, not user-made tags
After you make the plans, go to plan groups and ensure the created plans are in the same group
ASP is not offered on the CFMX servers. Only PHP and Perl are. You would need to create a standard windows acccount for asp, asp.net and frontpage support
In SDU, 100MB of disk space can be used by your customers for web, mail and database anyway they want. Just tell your customers - 100MB total disk space.
Just as a side-comment on Yash’s reply -
JodoHost will install 3rd party CFX tags as Yash mentioned above. When using your own CF_Tags you will need to follow the normal rules of directory searching and place the files in your web root or use CFModule to access them.
Jodohost will set up mappings as needed on a per ticket basis.
I’m not sure if this has changed but the CFRegistry tag has been disabled for obvious security reasons.
