I have an .swf embeded in an .asp page. In order to eliiminate the “click to activate” in IE, I have, hopelessly tried using the SWFObject. I have seen web pages that use some kind of other java script…unfortunately, I am not really a coder, but a mere designer. Could someone help me with this…i would be sooooooo grateful. Here’s the code that’s there…
[CODE]
My College Advisor ® - College Admissions in 3 Easy Steps!
[/CODE]
Thank you in advance for any and all help on this.
Thank you for your quick response. I have seen the first link (the Microsoft one)so many options… and was just going through the second one…it’s all rather confusing to me…I’ve tried a few to no avail. The problem I think…is making it work with the .asp
i’m not quite sure what it does either… something about parsing through all the object elements and reassigning it to the document object model i believe… either way, it works
