Flash Remoting Prob
Hello,
Ah. Hhh.
I had jodohost set up my flash remoting gateway. http://mydomain/flashservices/gateway .
I can test it locally using this domain from my computer and it works like a charm. Great.
I have now uploaded the same file, same code, to jodohost and I get no response. I don’t even get an error back.
Does the gateway url need modification or something?
All help is good,
-popAuth
Hello,
Ahhh. Ha.
I have the answer to the prob.
The swf file must be located on that domain which has the gateway applied to it. Make sense? I don’t understand why it will work locally, though.
Does anyone have any ideas?
Thanks for the help,
-popAuth
It is becasue the server is running the flash remoting built into CFMX 6.1 it is a bit more limited.
