I’m aware that Flash Remoting is still on testing stage, so i was wondering how’s the progress so far?
I really hope that it will be a standard feature in the hosting plan soon. So i was wondering if i can use trial hosting on Win2 to help test out the flash remoting?
Flash Remoting is working. This is the flash remoting gateway that comes with Cold Fusion and can only be used from Cold Fusion
If you want to use remoting, you signup for a new account and you’ll be put on Win6. Then submit a ticket asking for remoting to be turned on
yup! i’m using from coldfusion
thanx so much for the fast reply! ![]()
