hahahahahahahaha
For those of you who don’t care to visit that site:
http://www.coxar.pwp.blueyonder.co.uk/information.gifThese Weapons of Mass Destruction cannot be displayed
The weapons you are looking for are currently unavailable. The country might be experiencing technical difficulties, or you may need to adjust your weapons inspectors mandate.Please try the following:
[ul]
Click the http://www.coxar.pwp.blueyonder.co.uk/refresh.gif Regime change button, or try again later.
If you are George Bush and typed the country's name in the address bar, make sure that it is spelled correctly. (IRAQ).
To check your weapons inspector settings, click the [b]UN[/b] menu, and then click [b]Weapons Inspector Options[/b]. On the [b]Security Council[/b] tab, click [b]Consensus[/b]. The settings should match those provided by your government or NATO. If the Security Council has enabled it, The United States of America can examine your country and automatically discover Weapons of Mass Destruction.
If you would like to use the CIA to try and discover them,
click [http://www.coxar.pwp.blueyonder.co.uk/detect.gif Detect weapons](http://www.amazon.co.uk/exec/obidos/ASIN/074325239X/weaponsofmass-21) Some countries require 128 thousand troops to liberate them. Click the [b]Panic[/b] menu and then click [b]About US foreign policy [/b]to determine what regime they will install. If you are an Old European Country trying to protect your interests, make sure your options are left wide open as long as possible. Click the [b]Tools[/b] menu, and then click on [b]League of Nations[/b]. On the Advanced tab, scroll to the Head in the Sand section and check settings for your exports to Iraq.
[li]Click the [http://www.coxar.pwp.blueyonder.co.uk/bomb.gif Bomb](http://www.amazon.co.uk/exec/obidos/ASIN/B000053W4Z/weaponsofmass-21) button if you are Donald Rumsfeld.[/li][/ul]
Cannot find weapons or CIA Error
Iraqi Explorer
[size=2]Bush went to Iraq to look for Weapons of Mass Destruction and all he found was this lousy T-shirt.[/size]
Unfortunately doing the same thing with “miserable failure” doesn’t work like it used to.
The page where it used to link to is now the second genuine hit, though both that one and the new first hit are on the same subject
