The link to the forums on Jodohost.com goes to http://support.jodohost.com/ . So did all my shortcuts I had set to go to the forums. So for several hours I though the forums were down. Then when I finally got in on LiveHost to have a MySQL problem fixed, I found out that the forums are at http://support.jodoshared.com/ (notice it is “jodoshared” not “jodohost”).
I may be the only one with this issue, but I doubt it since the Jodohost.com link is wrong. Can a link be placed on the http://support.jodohost.com/ that will take the visitor to the proper forum address, http://support.jodoshared.com/ ? You may fix the website link, but there may be folks trying to access the forums via bookmarks that keep getting the wrong page. So a link on the page to the forums will help.
Sorry, Yash. I just tried it in Internet Explorer, and you’re right, it works. But in Firefox (which I recently started using as my default browser) it keeps taking me to the Web Utilities page. I’ve cleared the cache, but same result.
Is this a Firefox bug? Anybody else having this kind of issue? I switched to Firefox to help avoid this kind of crap. I’ll go back to IE if this is standard Firefox behavior.
Edit: Feel free to remove my post from the Chit Chat area about this same thing.
I only use IE and i was getting the same error earlier today. When i clicked the link on the front page i kept getting a the utilities page not the forum.I just put this down to the IP migration and sure enough it was sorted within a few hours. :]
It wasn’t a DNS caching problem, I checked the DNS directly using nslookup on your own nameservers. support.jodoshared.com and support.jodohost.com were both pointing to the shared Web2 IP.
