forwarding existing emails
hi
i would like to on a once-off basis - to forward all existing emails waiting in a mailbox, to a different address. its quite a bit of work to go in one-by-one and forward them, so i was wondering is there is a work-around of sorts to forward them all together - possibly to export and then import into the other mailbox?
thanks!
Hi, might be able to help out here, had a similar issue when moved hosts & needed to download my mail from old host webmail.
This is how I did it with outlook xpress anyway:
1.move mail in all your webmail folders into the webamail inbox.
2.setup a new mail with outlook…tools/accounts/add
enter the details per the wizard
3.click send/recieve all in outlook…you will now have downloaded all you webmail into outlook.
4.from outlook you can now “select all” & forward to the any email account you want.
Thanks!
i was hoping to do it all server side, but looks like what i have to do in the end.
thanks
