FTP Issues
Been having issues when connecting with an FTP client to my accounts. I cna connect fineand see the folders but if I open a folder that has a number of files in it it never seems to come back with the listing. If I abort the listing command it then shows a partial list. Not sure if this is my client or Jodohost. I’m using FlashFPX and Filezilla, both do same thing.
Command: LIST
Response: 125 Data connection already open; Transfer starting.
Response: 226 Transfer complete.
Error: Timeout detected!
Error: Could not retrieve directory listing
And the listing does not show.
If the folder only has a few files in it then it shows fine.
Any ideas?
Seems it may have been a passive mode setting. Turned that off and it seems fine.
I was going to recommend that :slight_smile:
Great :slight_smile:
So typically passive should be off? It seems some servers need it and others don’t. What exactly does it do and when should it be used or not?
