Hi
Does any other reseller face this issue ?
Win9 Server FTP file uploading is too slow..
It gets timedout frequently.
wanted to find if this is a server issue or my ISP issue
Indian
Hi
Indian
win9 cluster 1 or 2? I am not seeing any issue on either quite a few FTP logs on cluster2, and average on cluster1 (older server)
Sites on cluster2 win9 are also coming fast(heavy asp.net sites), I don’t know any heavy pages on win9 cluster1 to check ![]()
It is Cluster2
Only the FTP is having problems
My ftp is also quite slow. I know i am in Win9, but how can i check if it is cluster 1 or 2 ?
Win9 on cluster1 would be about a 4 year old account…or more.
I created my account in 10/09/2007. It’s almost in the limit, but below the 4 years mark. It should be in Cluster2.
Cluster2 main control panel login is goh******
Cluster1 is My***here.biz
this may help you to know as well.
these url’s are intentionally blocked, but it should give you an idea the URL I am talking about.
Cluster 2 then : http://cp.g********.com:80/psoft/servlet/psoft.hsphere.CP
FTP Should be fine now, kindly check it.
SIt is still very slow…
I am using filezilla and whenever it sends a PWD (to list the files), the server takes at least 10 seconds to respond, even if the folder only contains one or two files.
Please raise support ticket with the FTP login details which you are using, so that we can check the issue at our side.
