If you have, what’s your experience on it? Is the access reliable?
My clients tend to strictly use webmail and thus store a lot of stuff on the mail server (thus taking up my disk space). I figure with using these, I can let them store as much as they want and it won’t affect me.
The con might be that they are less reliant on me. Meaning if they wanted to move to another host, they could easily do so and still keep their mail. (This isn’t a huge concern of mine, but it is still a factor).
Still, if the email service is reliable, then at least I can free up some resources.
I have a few clients that like to store major amounts of email on the server. For these people I have them get a Gmail account and have all mail forwarded there from their domain account mailbox, with the domain mailbox set to not receive any mail. Then they can store all their email at Gmail. If they prefer to use webmail, Gmail is the only place they need to go. The caveat to this is that all sent mail shows as from Gmail and not their domain account mailbox. If using Outlook the outgoing mail server is the choice of the user.
For the most part (99%) Gmail has been very reliable for them.
They should be able to change that because Gmail allows you to change the From: address. Go to Settings / Accounts. As far as I know, its the only free webmail service that allows this. The others only allow you to change the ReplyTo.
I use Gmail exclusively for my email by forwarding to it and “normal” users never know that its from Gmail. They can only tell by looking at the full headers.
I tested this and if using Outlook it shows it coming from Gmail on behalf of the email account added in settings, so that really is only a half solution, although still better than not doiing it at all.
I was talking more about webmail, I haven’t tried Outlook with Gmail. It sounds like you’re using Outlook to send with smtp via Gmail. You really don’t have to do that. You can send out via an smtp server at your ISP or at Jodo and still pickup pop mail from Gmail. Your incoming and outgoing settings don’t have to be the same. That would still be transparent to the user. I don’t think there is anything compelling you to send through Gmail.
I just found out that in order to use the Hotmail for your own domain, you need to transfer your domain name to their registrar! Also you need to pay more for POP access via Hotmail.
I’ve added the new MX Server Address names (and deleted the old one) but for some reason the mail still keeps getting sent to Jodo.
Also, Google’s instructions provide a MX Server Address with a trailing period (“.”), but when I try to use that, hsphere gives me an error, so I did input it in without the trailing “.” so could that be the problem?
(I entered the MX records like this: CP > Select Domain Name > Hit the Edit icon for “DNS configuration”)
One more thing, when you try and add cusom MX Server Address, it asks for a Name and Data, with the Data comprising of what I assume is the Priority and the MX Server Address. Can the Name field be anything? I just named it mx1, mx2, etc…
If you dont need mailservice hosted here, disable it and then try.
This may happen in cases where your new domain and the domain you are sending mail from to test, are on same mailserver.
For MX you need to keep the Name field blank.
To the other’s that are interested, these are the steps that I took to get it to work:
Login to your control panel.
Select the domain name that you want to change the DNS.
Delete the “Built in MX records”
Click on “Add DNS MX Record”
6a. For the [NAME] field, leave it blank.
6b. For the [DATA] field, in the smaller input box, enter the Priority.
6c. For the [DATA] field, in the larger input box, enter the MX Server address. (NOTE: No trailing period “.” is required.)
Also, I have 2 more questions:
Is there anyway to forward [mail.domain.com] to [google.com/a/domain.com/]? I was thinking of modifying the CNAME, but that CNAME doesn’t seem to allow slashes “/”
If I disable Webmail on Jodo, does anyone know if that will affect the windows mail componet (CDO), i.e. sending mail via a contact form on my site?
I have Google Apps setup for one of my client’s domains. Everything works great except contact form submissions on their site.
I’m assuming this is because the CNAME record still points to the old mail server. Should this CNAME record be changed to ghs.google.com as I have seen some other forum posts mention?
Also, the smtp server used by the website is mail.[domain].com. Earlier in my time with Jodo I had problems using localhost, so everything uses the fully qualified name now. Should that now be changed to localhost?
We have changed the localhosts to work with a proper FQDN now as well, they can still get blocked in some cases but mail delievery is much better now overall.
