JodoHost Staff,
Is it possible for resellers to use this signup script? It requires access to the admin database, but I hope that you can host it for me under a third-level domain. i.e. domain.mydomain.com.
JodoHost Staff,
That is sooooo much better.
i’ve been busy, but i did get the api sign up script working, and a number of others, and know how to get all working.
MetaSkinny, it requires too much access
It is not something we can offer at reseller level.
That’s a pity Stephen..because it looks so much better than the standard one ![]()
To add, people have face problems with this script who attempted the install themselves. Also there is no post-install tech support available as mentioned by developer on Psoft forums.
Does anyone know of a PHP solution for resellers?
I guess a few here are using it for a while.
You can search for a few discussions here and on psoft forums ( forum.psoft.net)
[QUOTE=Emagine]
I would like to see a working demo that a reseller could use.
There are plenty of examples of custom signup forms available to the CP owner, but not the reseller. Or, at least I haven’t been able to find any working examples for resellers.
ok i have it as an asp function
i use AddUser(value, value, value,value,value)
then that function send a request to th ecp, and submits the user, when i made th efunction it sent th euser , but as ive been informed as soon as jodo upgrade to 2.5 it wont work so i will look into the new version.
i have a range of envelopes working
please pm me a email address and ill email you the functions
