help with deciding which plan
Hi All
Can someone suggest which plan would be best for my needs. I want to host a minimal content site that is specifically for email accounts. I may need to host a second site that is the same and finally a third that would host a BBS, eg vbulletin
Thanks in advance
:slight_smile:
You can go for either Windows ( www.jodohost.com/windows.asp ) Or Linux Hosting ( www.jodohost.com/linux.asp ) packages. You may start with VALUE package as it allow you to host 3 domains. You will be able to host vbulletin too.
Thanks Gurmeet, I’lll have a look! :slight_smile:
Another question…is there any limit to the number of email accounts that can be used? Also what is the storage capacity of each account and roughly how does 12Gb per month relate to email account usage…what I mean is do you know roughly how much bandwidth 1 email account would use per month (assuming there were no attachments)…Thanks again
the quota is ‘summary based’ so it means it is all inclusive of web/email/database
Personally, I get multiple thousands of emails monthly, and on my phone it uses about 220MB of bandwidth total, that includes some web browsing as well :slight_smile:
This is from my phone bill statement, so it should be pretty accurate.
Thanks for the info guys!
:slight_smile:
