3 Days ago I switched 3 WordPress sites (PHP/MySQL) over to Jodo. From my end 1 loads fine, one is real slow, and one will not load at all. They all worked fine the first day.
I have checked them from work and home and got the same thing - slow.
Note - Jodo Support has been looking into this all day for me and they have been great. Unfortunately they look fine from their end possibly because they are in the same location.
They are loading in 5-7 seconds for me with DNS lookup, which is slightly slow but not too bad.
There is no way the staff on ticket or livechat could be looking at them in the same place. Most of them are in India, and I am in Texas, all over 1300 miles from the servers.
The staff in Florida does not participate in the daily tickets and support operations in a visible manner.
I am having Yogesh check it, because it was a bit slower than it should be, but not dramatically slow.
My opinion Zohosheet waxes google’s floor in the online spreadsheet market.
I was not doing anything complex in it, but it was just working better than google’s when I used it.
Google was a number of times very very slow, and I had trouble FINDING some of the formulas initally in google(just had to search some), where zoho looked more common.
Coming up with the wrong sheet, that is not good, I did not have that. Zoho is backed by AdventNet that makes some nice products like ManageEngine.
Anyway, my issue seems to have been semi resolved. When i setup my domains I used NS1, 2, 3, and 4 for DNS and this was causing an issue because I guess you are only supposed to use 3 and 4. I have changed this with Godaddy.
How this was affecting me was that I had Google Analytics and a shortstats plugin that both where making requests out to different domains. I guess because of the DNS issue that they where not able to find their way back to my site so it was causing my pages to load slow or not at all.
So, I will wait a couple of days for the rest of the world’s DNS servers to get up-to-date and then see what happens. I am sure it will be fine from this point on though.
I have to say that the support is excellent though. I did not get near this amount of support from the other company that I was with and that is why I am here now. It was a error on my part but they made sure that it got fixed.
