We did set-up a mailing list for a client of ours and the whole list works fine for subsription if you just send the email through a standard mail client, however if the mail is send via a website form either through sendmail on the server or even Frontpage extensions mail delivery the subscription does not work (even looks like the mail is not being sent).
Sendmail and frontpage extensions work fine, as another form on the same domain delivers perfectly all inquiries directly to our clients mailbox…
I am out of ideas and very open to anybodies thoughts and ideas…
Get confirmed if you have selected option “Posts from addresses other than moderators are rejected”. If Yes then subscribers wont receive mails sent by other than moderators.
[QUOTE=Nidhi]
Nidhi, I appreciate that you tried to test it, however, you tested the wrong mailing list and if I make changes on the original mailing list ([email protected]) it still does not work via the Web Form ! However works fine if I try to subscribe via Outlook…
I had some issues with getting web page-based subscriptions to mailing lists to work on a win server here. It seems that ezmlm picks up the wrong address: it’s supposed to pick up the From address and sign up that person to the list. But, on Windows, it seems to pick up the Return-Path field instead.
My work around was to enable remote administration. Then, I created my mailer to send the mail to:
When I set-up formmail.asp on the windows box to send the subscription to the mailing list it works like a charme, however when I send from a linux box with formmail or frontpage form submission it does not work…
Are you certain the message is being sent out? Like, have you tried sending mail via formmail or frontpage to other addresses to confirm that mail is sending? Have you configured the frontpage components in your control panel? (Mail won’t send if you haven’t.)
[QUOTE=skypanther]
YES and YES … formmail works fine and so does the Frontpage Mail component…
