hi
i have msn 7 beta but i have not the drawing program all my friend who have msn 7 like have the drawing prog.
any one can help me
what i have to do get it?
are you sure you don’t have it down near the bottom? There should be a tab.
Also, have you been to windowsupdate and updated directx and other programs? That might be why it is not there.
hi
no it it is not there
yes i have update the windows but have not updated directx how and where can i find it?
It would be listed under optional software.
or XBOX Games | XBOX
now have i installed the directx what other can i do to get the drawing program ???
i have installed the directx program ..what other can i do to get the drawing prog.???
Download and install the Windows Journal Viewer:
After installing, exit MSN Messenger, and start it again.
You’ll have the handwrite tab at the bottom.
