Horde again
Hi
Horde is not working. Customers are using their usual username/passwords but this time there is no mail server for choosing. The login attempts are always rejected. I opened a ticket several hours ago but got no answer
Please fix
There was a link problem on mail.youdomain.com
webpage, which has been fixed. Also if you want to
access it directly kindly use the following link:
http://63.209.158.6/horde/imp/login.php
Now I can log in, but when I access Horde from
http://mail.mydomain.com
Once logged, I cannot choose the sent or trash folders. Also, there is a link “eliminate” instead of the “Delete” links among other changes
Please restore the interface.
P.S. Using the other link that you provided does not have any problem, but using that link is not an option for my customer
You ticket in this concern is replied.
The interface was already restored as mentioned
in my earlier post. You probably are getting the
older version on the page from some cache.
Kindly get the cache deleted at the relevant
end and reply your ticket if you still face this
problem.
