Do old stats periodically get cleaned out automatically?
Tim
Tim
i don’t think so since they are stored in your web space and take disk space out of your own allocation. I believe it’s up to you to clean them out on your own.
Do you mean the log files or the processed AWStats or Webalizer files?
Just an observation from my accounts, it seems like we keep the last 6 days of gzipped logs. I would expect the stats to last until you delete them. They really don’t take much space.
i was referring to the processed files.
Yeah, I was referring to the processed files in the /webalizer directory not the raw logs.
For some reason, I thought they were cleared out periodically. Though, I couldn’t find anything saying that in the PSoft docs. I guess not.
Tim
