how much Space I get for SQL
Is there a limiton the space on the database size ?
do you backup the db (bak) files everyday or how often ?
Thanks a lot.
Bill
No, infact you can use all the space permissible under your plan for your database.
Yes, Backups are taken daily.
Thanks Ravi,
Bill
