Hi
guys…How to do design generic data layer in dotnet
Thanks & Regards
Ramanatha Reddy
Hi
Thanks & Regards
Ramanatha Reddy
[QUOTE=Ramnath]
Hi
Thanks & Regards
Ramanatha Reddy
Here are some places to state:
MS Application Blocks - look at the Data Access Application Block - http://msdn.microsoft.com/practices/guidetype/AppBlocks/default.aspx
Then look at the Data Provider Pattern that is used in the DotNetNuke portal. This is exactly what you’re looking for.
[QUOTE=Homer]
Thanks Homer
