How to install Isapi Rewrite Help
Dear all ,
Thank you for reading this , i’m so new to this field . My web developer from oversea complaining cannot install Isapi to my VPS because it’s in different language format . Now i’m trying to figure out by myself , where should i start? Just download it? And install? Can someone submit a tutorial ?
Hello,
Do you have Windows 2003 or 2008?
Using asp, or asp.net?
If 2008 and IIS7 here is a great resource:
http://learn.iis.net/tags/URL+Rewrite+Module/default.aspx
If 2003 let me know will give you some other options.
