So does this upgrade support Awstats. I remember reading from you guys that this would be supported in the future upgrades.
Just checking
Bryan
Just checking
Bryan
Yes, HSphere 2.4 supports AwStats. It’s currently not working but we will be fixing this within the next 10 hours and an announcement will be made
cool ![]()
You can now use AwStats. Turn it on from the control panel and use your ftp username and password to login
I’m still getting the code listing for my site on win5.
OK, then add .pl as a CGI extension (from web options)
That worked. Thanks for the quick reply.
I have turned on AWStats this morning, but there is no data shown. Do I need to disable Webalizer?
Also is it going to be possible to keep logs for more than a week (like currently with Webalizer)?
Nathan
I also turned on AwStats, but no data is showing. At the top I have the following message:
Never updated (See ‘Build/Update’ on awstats_setup.html page)
Where is the awstats_setup.html page?
When I use this to log in I am shown a 404 error message. Am I missing something here?
Thanks!
There is a problem with Awstats that we are working on…
Sorry for the inconvenience, it should be fixed very soon
AWStats is much better than webalizer. Very nice features.
