We will be performing scheduled maintenance on Hsphere CP on Saturday, Feb 17, 2007, starting at 11PM EST. It will take 3 hrs for this process to finish.Control panel will be down during this maintenance however other services will not be affected.
Re: Hsphere Control Panel:Scheduled Maintenance Sat Feb 17 11PM EST
We have stopped control panel for maintenance.
Maintenance is in progress but it may take 2 hours more than posted outage.
We have started control panel however maintenance is not finished yet.
we are doing just regular maintenance this time and the proposed maintenance will be done next week.control panel has been running and will keep running. it may just run a bit slower for next few hours
Regular maintenance has been completed and Hsphere CP come back normal status and running fine.
Please note that Deffered maintenance will be done on saturday 11 PM EST.
At this moment it appears the maintenance can take 3 hours more. The process cannot be stopped. We will post further updates as they are available.
The maintenance included recreation of the Hsphere database, but after many hours of restoration process it errored out towards completion, leaving the system database in inconsistent state. We are having to redo the maintenance again and it can take another 6-7 hours for the restore to complete.
Unfortunately there is nothing we can do here to avoid this downtime unless we have the Database restored in correct state.
We deeply apologize for the inconvenience caused.
The ticket system web interface(GUI) may not work as it uses Hsphere for authentication. Kindly email directly to the following support addresses:
[email protected] (if you are a shared customer)
[email protected] (if you are a reseller customer)
I am just bumping this topic back to the top as this maintenance is ongoing.
From this point, the maintenance should finish in approx 1.5 hours.
The maintenance is still not quite done, but it seems to be nearing completion. We do not have a process level indicator so we must by by file size alone, so it is only an estimate.
The index rebuild is taking ages as some tables have millions of records and have multiple indices. We do have taken all measures to keep at its fastest pace, but in the current situation we cant rollback or stop.
We will sure go back to the drawing board to see what we have missed here and how we can prevent it from happening again. The delay however mostly has been due to the error that popped up causing us to redo the whole maintenance.
I’m thankful to our customers for being patient and cooperative during this whole maintenance.
Control panel maintenance has finally finished, leaving some minor issues related to daily resource calculation and billing. We will have Psoft look into it and resolve at the earliest possible. The maintenance was planned to resolve control panel occasional slowness issue. While all was done as planned, we were forced to do the whole process twice as it errored out in during completion in the first run. The database being talked about here is huge in size and maintain multiple indices to maintain momentum of the control panel. Rebuilding them takes significant amount of resources and time. This resulted in much longer and unanticipated downtime. We sure have it on our notes now and would like to assure our customers all steps required to mitigate such issues in future will be considered.
Thanks again for your cooperation!
Psoft may be performing some minimal but important maintenance on Hsphere control panel on Friday, March 2, 2007, starting at 2:30AM EST to resolve a few issues.This maintenance will take around 1hr and 30 mins, and control panel will be down during this period.
Maintenance has been started by Psoft a few minutes back.
Psoft has already completed the maintenance and identified the issue. It has been escalated to the Hsphere development team who will be available on Monday for further analysis.
Control panel is also up and running for last 15 minutes. It may be slow for next few hours as all pending calculations and routine tasks for last 4 days are being completed today.
An update: We now have a Hsphere developer looking into it.
