A client tells me he can’t publish to his site from F-P any more. It used to work. I can FTP in using his credentials. Could this be upgrade related?
He’s on win28. I’m trying the “Fix FrontPage” button, though the CP is being very slow. (My sarcastic view is that the Fix FrontPage should probably mean to just uninstall it!
Tim
Yep its one of the only lingering issues, I am to the point of just wishing MS would officially kill FP extensions
Much of the ‘slowness’ n fixing FP is due to it trying to change the permissions etc, and sometimes failing as they already exist for the most part.
We can and have been fixing them manually.
Well, after an hour and a half waiting for the “fix” button to do something, I think I’ll submit a ticket for a manual fix. Thanks Stephen!
Tim
