HSphere upgrade to 3.4 - Starting Saturday, November 27, 2010 at 11:30 PM EST
We plan to upgrade our servers to HSphere 3.4 starting Saturday, November 27, 2010 at 11:30 PM EST.
Control panel will be stopped for 4 hours for the upgrade to complete, and individual services may not be available intermittently during this time. Servers may be out of communication with the control panel for a longer period of time, which only means there may be a delay in using control panel.
This is primarily be a bug-fix update. There are certain new features that this upgrade allows to make available. However, their final availability will be announced separately.
Update discussion thread:
http://support.jodohost.com/showthread.php?t=21714
Upgrade is starting now.
Control panel core update done. SiteStudio update in progress
SiteStudio update has failed. We will look into this towards the end.
Control panel continues to be available, however there may be errors as we update the individual servers.
web8 updated.
mail1 updated. mysql1 update in progress
Winsd1 is done, Winsd2, mssql1/2/3 going now.
Mysql update is taking much time. Looks like these updates will take a few hours.
mysql1 update is done.mail5 update in progress.
Well on the windows side, the servers are up, which is the good news, but it is going to be a bit before connected to CP fully, while it upgraded the core it is failing on upgrades of feature packages and I am doing them manually.
SD servers worked well, shared seem to have more in features in use that are locking files from upgrading.
mail1,mail5, web4,web5,web2,mail3,web1,mail2 updated.
IMAP services are seeing problem on mailservers update. We are looking into this now.
IMAP issue fixed. web3,web6 updated. mysql2 update in progress.
Win10 is done, 8/9 are midway done, but some packages take a while, and win5/6/7 are attempting the auto update, we will see if it works or not.
Win 8 and 9 are both done now.
Win7 to 10 done.
Win1 finished up in the automated side properly.
Others still going.
Only a few MSSQL servers, and Win2-6 are pending. Rest all are updated.
Win2 has completed now. win4 also just completed.
