Hello, can anyone help me?
When I connect to my sql server database via dreamweaver asp.net, i get the following error:
http 403 error code forbidden <<
Help, it’s driving me crazy!
Your directory index is set to look probably at index.html by default. Sounds like to me you don’t have this file in your root folder, so create one and place it there and it should work.
I am having this problem and have had it in the past. I am on web3 trying to access mysql3. I am using PHP and get this when trying to create recordsets and also get it when trying to view existing recordsets in DW that have always worked fine before.
This is quite urgent. I will open a ticket but thought someone could help.
is it 403 or 404?
It is always better to create a ticket.
