I get an error with IE 7 that I don’t get with Firefox. I’ve never seen it before actually.
Webpage has expired
Most likely cause:
The local copy of this webpage is out of date, and the website
requires that you download it again
I’m seeing it with this new enviro calculator I’m developing.
Visit Lighting Cost Calculator
Select an electric rate
Select a type of light bulb in the left-most column
Select a wattage
Click Calculate
The page works just fine in Firefox but not in IE. Funny thing, I did my development and initial sharing with the pages at my demo site and I don’t get the error when I load the pages from that site. Other than some different styles and some table wrappers to fit the scheme of the SELENE site, there are no other differences between these pages. It’s the same files and database.
I get the same error on my localhost computer (using localhost or 127.0.0.1 in the URL).
Hey Tim,
I cannot add too much except that I reproduced the error on IE7, OK on FF.
My only question would be if results.php is exacly the same on your dev machine as your production. If not, what happens when you sync them?
Tim
Tim and Stephen - Thanks for confirming the problem. I hadn’t made any changes, and it still wasn’t working for me. But now I have and it’s working.
I’m still unsure of the source of the fault, though.
The index.php and results.php files both include the same header & footer files. I had changed the header/footer files for the SELENE site to wrap the content within the table-based layout of that site. By putting back the original files, now the page loads in IE.
So, there must be something in those files that IE doesn’t like—but only with the results page. Because the index page loads just fine.
One very minor suggestion - on the results page (which worked for me in FF2 and IE6), don’t say “due to rounding errors”, perhaps say “due to decimal rounding”. Just so laypeople don’t think something is “wrong” with the figures.
Here’s what I found, if I include the header and footer HTML in my header.php and footer.php files, IE throws the error. If I put it in the results.php file and I leave out the table that wraps around the results output, then IE is fine. If I wrap the results output in the layout table to get the left/right border images, then IE throws the error even if that table is in the results.php page. I tried various php and HTML header, cache control, and expires thingies to no avail.
I tried various CSS ways to get the borders and either IE or FF showed ugly gaps or misalignments in one place or another. It’s not worth it. I’m not being paid, this is just a hobby, cause thing for me. So, good enough. When I have a chance, I’ll create a new banner image without the borders so the page isn’t quite so ugly.
@antic, thanks for your input. I updated the “rounding” text.
Thanks all!
Tim
PS - I am fairly confident in the accuracy of the calculations. I have compared them to various other calculators on the web. So, yes, leaving a single 100 watt incandescent bulb on dusk to dawn (like a porch or garage light) does indeed cause the release of a half-ton of CO2 per year.
i know this post is over two years old, but i came across it because I was having similar issues to the one described..
ie giving page expired errors for a php developed page, and the problem was not seen in FF.
what i found is that i was using “#” to reference and reload the current page…after removing these references and adding the real page name (ie index.php) these errors seem to have gone away…
im curious to know if this may have been the case for your issues as well.
anyway, hopes this helps someone
Thank you for posting the solution, it has REALLY helped me.
I’ve just spent 2 days trying to figure out why I was getting ‘Webpage has expired’ in Internet Explorer 8 (no problem with Firefox, Chrome, Opera or Safari).
I searched and found various suggestions but you have the only one that works for me.
Simply replacing the ‘#’ in action=“#” with the real page name solved the problem!!!
Thanks again.
