IIS or Apache?
One of our clients is setting up SSL through GoDaddy and one of the questions they ask is what web server software we are using. Can someone tell me if the reseller accounts use IIS or Apache? Our account is under bassodesigngroup.com. Thanks.
if you install via hsphere you can just select apache and it will work :slight_smile:
