On my local testing server I cannot use a directory like mysite.com.
I use dreamweaver so I renamed my directories to mysite.com rather than mysite for ease in uploading to my accounts here but for some reason it will not view a page in a directory with a period in it.
How do you mean wouldn’t display? Do you get an error? I would imagine its dreamweaver because I also have directories with periods in running perfectly on Win Xp Pro IIS
[QUOTE=Stephen]
It should be in c:\windows\system32 I believe, if it is not on your PC that could be part of the problem
It’s c:\windows\system32\inetsrv
I have a metabase.bin and metabase.dll but no metabase.xml
This is as bad as when I had norton internet security installed. I could not open the IIS window when it norton internet security was on my system. I could never get a response from symantec either. It may be what corrupted it.
I’ve had problems with domain directories using .com when they are in the inetpub/wwroot directory. Making a virtual directory in IIS to the actual development drive fixed the problem. XPPro only allows you to serve one website, running additional .com directories off of inetpub/wwwroot/ seems to throw an error.
I’m not sure if that is the problem you’re having. I’m also not sure if it should have been a problem for me. I don’t have a lot of patience to figure out those types of problems if I can get it to work one way or another.
I have little experience with iis. I will see if I can figure out how to do that. I have always tested all of my sites on my comp. They were all just nested below the main site. I never had an issue till now with IIS except with norton internet security.
