Does JodoHost use IIS6 HTTP Compression? If not, can I recommend that you turn this on. It would be of great benefit to everyone using DotNetNuke. It has been highly recommended to do so from the DotNetNuke Threads at ASP.NET. The following link is what is quoted in those forums:
Given that the all of sites I code (and hence, host) are custom, not dotnetnuke and many are updated by the minute, I’d request that this feature NOT be used as well…
