Incorrect SSL instructions
Just a FYI that the instructions at http://www.psoft.net/HSdocumentation/user/ssl.html#existingcertificate specify we should specify Apache as the server when requesting an SSL cert even for a Windows box. This does not seem to be true. If your client is on Windows, then you should select IIS when requesting a certificate (according to JodoHost live chat representative).
Is there a way to get this documentation changed? I could have been out $200 if I followed this advice. The screenshot here also doesn’t match the options I see in my client CP.
You’re going to have to ask PSoft about that, not Jodo. They are separate companies. PSoft makes HSphere, which Jodo and many other companies use.
Tim
