INSERT INTO problem
[FONT=Trebuchet MS]I have a quite difficult problem and I need help!!!
I have a table and I have to insert a few hundred rows with these columns:
Email
When
What
I could make when and what with VALUES like
INSERT INTO emaillog(when, what)
VALUES (050712,P:\db\RAM Price List 070512.zip)
This is okay. The problem is with the emails. Those come from a query, I have a few thousand. So the new rows should look like this:
[email protected] 050712 P:\db\RAM Price List 070512.zip
I really don’t know how to do that…
I tried…
INSERT INTO emaillog(email, when, what)
VALUES (
(SELECT email FROM ram_070515query), 050712, P:\db\RAM Price List 070512.zip)…
but it didn’t work…
PLEASE HELP ME, I don’t want to type in hundreds of rows!!![/FONT]
Are you saying that these 100 or so records are already in a table? If so, you could try this:
SELECT ? INTO
tblEmailLogs
This select statement selects all records from one table, and then creates a new table with those records in it.
Richard M.
[FONT=Trebuchet MS]The contacts are in a table, and I get out certain email addresses by a query. I need to add these emails to another table with a date and a subject.
Actually I’m using MS Access… Can you help me?[/FONT]
You would probable require to use a join between these 2 tables by matching a ceratin pattern.
Access can create a good query in design mode. You have to just select tables, establish relationshiop between them and specify the records you want.
[FONT=Trebuchet MS]OK, I’ve solved that with this:
INSERT INTO emaillog ( Email, When, What)
SELECT email, ‘20050712’, ‘P:\db\RAM Price List.zip’
FROM ram_050712query;
Thanks for the help guys![/FONT]
