Installing a CMS
I’d like to use a CMS with my website and am thinking of using Mambo as it seems very popular.
Is it actually possible for me to install Mambo for use with my jodohost hosting account? If so, into which folder would I install the the files?
Thanks for any help.
you should be able to just run the installation of mambo through a browser window after you upload the files, i dont think it matters what you name the folder you upload it to.
Mambo does look cool. I just found it, I also saw Drupal. But I’m not partial to PHP so I tried DotNetNuke which seems really cool. Not quite as established as the older CMS’s though.
