I got stuck while installing SQL on my Linux VPS the error, is in bold and Im not to sure what to do, install libstdc++ or any other ideas?
[root@ninny mysql-standard-4.1.21-pc-linux-gnu-i686-icc-glibc23]# scripts/mysql_install_db --user=mysq
Installing all prepared tables
./bin/mysqld: error while loading shared libraries: libstdc++.so.6: cannot open shared object file: Noh file or directory
./bin/mysql_create_system_tables: line 663: 14386 Broken pipe cat <<END_OF_DATA
use mysql;
set table_type=myisam;
$c_d
$i_d
$c_h
$i_h
$c_u
$i_u
$c_f
$i_f
$c_t
$c_c
$c_ht
$c_hc
$c_hr
$c_hk
$c_tzn
$i_tzn
$c_tz
$i_tz
$c_tzt
$i_tzt
$c_tztt
$i_tztt
$c_tzls
$i_tzls
END_OF_DATA
Installation of system tables failed!
Examine the logs in ./data for more information.
You can also try to start the mysqld daemon with:
./bin/mysqld --skip-grant &
You can use the command line tool
./bin/mysql to connect to the mysql
database and look at the grant tables:
