Installing SQLEXPRESS
Hi friends,
I’m running an ASP.Net application and I’m using memberships. For this I have to have SQLEXPRESS installed on my VPS.
I downloaded the pack from MS site but when it was checking the system it showed a yellow “!” sign saying that my hardware has an incompatibility with that software.
Is there something I have to have in mind when installing or using SQLEXPRESS in my VPS? What could be causing this?
Are you sure it is hardware and not software?
There are many people doing SQLExpress on their VPS.
Thanks Stephen, this is the message it shows:
  • Minimum Hardware Requirement (Warning)
    Messages
The current system does not meet the recommended hardware requirements for this SQL Server release. For detailed hardware and software requirements, see the readme file or SQL Server Books Online.
Thanks again
Do you have a VPS Value account? While I have seen it installed on here the RAM may be a bit low. that is the only thing I can think of that may throw an ‘hardware’ requirements too low
Yes I do…
Well, actually I just ignored that warning and went ahead. No problems so far.
I’m just attaching the ASPNETDB database now.
Thanks!!
